Helson ... la suite
+19
Yannick
kikinoulator
cisco
23 participants
Page 1 sur 6
Page 1 sur 6 • 1, 2, 3, 4, 5, 6
Helson ... la suite
Mr Helson ne propose ... rien au problème de ma montre, tout jouste de plates excuses !
en ayant vraiment MARRE de ces conneries j'ai décidé de lancer une petite campagne dont Mr Helson devrait se souvenir :
voici le post que j'ai fait sur les fora anglophones suivants : WatchUseek, Equation of Time, TimeZone
si vous avez idée ou je peux le poster je suis preneur : trop c'est trop
Helson or the wanabe diver ...
Let me tell you the story I have experienced with Helson watches
I may introduce myself breifly : I am a watch collector since more than 20 years and I focus my collection on dive watches : this passion for dive watches is linked to my sport activityI am a diver since 1973today PADI Assistant InstructorCMAS *** and IANTD technical diver rEvo rebreather diver
When helson watches first introduced their re-edition of the Omega Seamaster 1000I jumped on the occasion to have an historic look diver without the fear of diving with itso I ordered the Sharkmasterone of my diving buddiesJean-Marc also ordered that watch... and the nightmare began...
After a dive at 40 meters the watch was completly flooded ! quiet a disapointment for a piece supposed to be 1000 meters waterproof ... Peter Helson replaced the watch with anotherbut not in the configuration I had ordered ! (lefty and black date instead of standard with white date)as I was a little bit pissed off sending back to Hong Kong the watchI decided to keep it like this ... but not for a long time
Jean-Marc faced exactly the same problem with a dive at 17 meters : the watch was flooded and he asked for a replacementon his side the watch was the same model as he had ordered
For my first dive at 20 meters with the new Sharkmasterthe watch was filled with condensation : game over !
This time I asked Peter Helson a full money refunJean-Marc asked for a replacement ... and flooded it again !!!! as he really wanted the watch he asked for a replacement : at last his third Sharkmaster was waterproof !!
Sharkmaster : 5 watches (2 on my side3 on Jean-Marc's side) only 1 really waterproof
You should think the story finally had a happy ending ... but call me madI thought this was only bad luck and Peter Helson seemed really sorry for thoses bad storiesso when the Skindiver was issuedmy wife who is also a diver liked so much the design that I ordered again from Peter Helsonand guess what ... the watch was full of condensation at the fisrt dive ! hopefully my wife discovered the condensation only at 11 meters so she aborted the dive and got back to surface !
Peter Helson this time did not seem to believe my storyand even did not propose to replace the watch immediatly ... after several e-mail exchanges he admitted that there was a potential problemtoo late for meso I decided to open the watch and have a lookFirst what stroke my mindwas a dry o ringand 2 little metal particles inside the casethat is what you can probably expect from a watch made in hong kong ?
The design is a complete nonsense : 3 bridges are bent from an external ring to avoid movement movesbut thoses bridges bent manually prevent the caseback to fully close ! : the watch is waterproof 1 to 3 metersafter it leaks !I have tested the watch is a «wet» tester where you can perfectly see the bubbles coming out from the caseback
As Peter Helson did not propose me any real solutions (send the watch back so the factory «can have a look»)I decided to fix the watch by myself : I bent the bridges down so they do not touch the caseback when it is screwed backand guess what .... I solved the problemI have tested the watch at 5 ATM and finally it passed the testSo if you intend to dive with your Helsonbe warned that you might be obliged to finish the job by yourself
Peter Helson never proposed me any arrangement for this problemso I decided to tell the story over different watch forums : when you buy from Helsonyou buy a wanade diverfar from what you can expect of a real dive watch : a Seiko diver 3 times cheaper does the job !
I personnally always dive with my watchesnot as a real dive tool but for pleasureand I have never been faced to such a failure ratio with any manufacturers !
Re: Helson ... la suite
j'aimerai aussi toucher des fora gernanophones , les fora espagnols ont déjà été couverts (foro de rolojes et RPT)
Ah enfin !
Je sens une auguste colère à la mesure de la belle patience dont tu as fait preuve...
- Nombre de messages : 5465
http://www.thewatchforum.co.uk/
http://www.mwrforum.net
Pimousse- Rhincodon typus
- Nombre de messages : 5575
Generalement il faut les menace d'appeler la repression des fraudes, c'est ce que je fais quand j'ai un probleme (en france), ils ont tellement peur que ton probleme se regle assez vite. Apres je sais pas comment ca marche pour l'international il doit surement avoir un organisme qui controle ce genre d'arnaque.
Cordialement
Cordialement
Marabou- Galeocerdo Cuvier
- Nombre de messages : 855
Je crois que le WUS va être violent pour une marque comme Helson...
Pour les Germanophones je suis pas dessus.
Y'a watchlounge.com qui est un gros sinon je ne sais pas trop.
C'est aussi la différence entre fabricant, emboiteur et revendeur.
Le vrai fabricant a un pouvoir de controle sur ce qu'il fait. En général le boitier.
Les cadrans, les mouvements et les aiguilles proviennent souvent toujours des mêmes sous traitants en général sérieux.
Si on ne fait qu'emboiter on est quand même censé pouvoir controler ce qu'on emboite.
Si on est revendeur de trucs tout prêts fait à pas cher... ben là évidemment non seulement on paye plus cher mais en plus on ne contrôle rien....
my 2 cents
EDIT: +1 avec Pimousse: MWR ....
my 2 cents
cisco- Rhincodon typus
- Nombre de messages : 3069
Y'a un bon début de débat sur WUS ,
Jean-Mi va t-il y pointer le 420 ?
Léo29- Rhincodon typus
- Nombre de messages : 2244
c'est posté sur MWR
C'est bien ce qu'on disait. Sur WUS quelqu'un s'étonne qu'un petit groupe de plongeurs dans une partie du monde (sous entendu dans le trou du cul du monde) soient les seuls à avoir ce type de problèmes.
Faut vérifier l'eau de vo
et oui faut dire que sur WUS c'est vraiment le coin des wanabe divers .... mais vu l’audience du dit forum il était important d'y poster
Quelqu'un peut me refiler le lien vers WUS pour que j'essaie d'y comprendre quelque chose malgré mon faible niveau en anglais (mais je viens de valider un niveau aujourd’hui ) ?
micromeca a écrit:Quelqu'un peut me refiler le lien vers WUS pour que j'essaie d'y comprendre quelque chose malgré mon faible niveau en anglais (mais je viens de valider un niveau ajourd'hui ) ?
http://forums.watchuseek.com/f74/helson-watches-wanabe-divers-545787.html
Moi je remplacerais l "AUTOMATIC INCABLOC" du cadran par
Lavage de mains = Ok++
Piscine = Ok
Plongée = Faut voir
Piscine = Ok
Plongée = Faut voir
édifiant !
- Nombre de messages : 6416
Le débat sur wus croustillant a souhait merci pour le lien jm .
Éric
Éric
Mahoro a écrit:Le débat sur wus croustillant a souhait merci pour le mien jm .
Éric
+1
- Nombre de messages : 4952
tant mieux si il y a débat ... même si 99% de ceux qui postent n'iront pas plus loin que le fond de leur baignoire ... ça fait le buzz et c'est fait pour ça
je suis sur qu'il y aura un impact : et tant mieux
moi quand on m'en fait trop j'correctionne plus j'disperse , j'ventille
Mdrrrrrrrrrr y'en a un sur WUS qui a voulu ouvrir sa montre pour contredire JM. Et il a foiré le fond
Ca va être l'hécatombe
Oui j ai lu ça j étais ptdr pour son fond . Trop futé celui la .
Éric
Éric
Mahoro a écrit:Oui j ai lu ça j étais ptdr pour son fond . Trop futé celui la .
Éric
+1
Entre celles qui prennent l'eau , celles qui sont démolies par des gars qui veulent contredire Jean Michel , il va pas en rester beaucoup des helson ...
Éric
Éric
Comme d habitude certains americains refusent de voir la verite...
Qu ils disent, a la rigueur, vu l utilisation que j en fais, ca me suffit....
Mais qu ils nient l evidence ou le manque a pas de bol....
Mais c est dur d admettre qu on a pas achete un produit parfait....
C est pour cela que j ai horreur des commentaires sur les sites d achats, generalement les personnes sont contentes de leurs merdes.... c est des moutons.....
c'est une vraie delectation la lecture de WUS!
merci JM d'avoir lance la machine. ...
il y a meme le heros qui serait content si les montres etaient testees a 1/10e de leur performance affichee.
mouah aha ha
mouah aha ha
C'est une perle ce fil sur WUS, vraiment poilant.
Ce qui commence à m'étonner c'est qu'il n'a pas encore été édité...
a partir du moment ou la marque Helson n'est pas "sponsor" de WUS je ne pense pas qu'il sera édité .... WUS est une farce coté étique : si tu as le malheur de dire le moindre mal d'un sponsor tu gerbes, c'est comme cela que j'ai quitté WUS (j'avais osé dire du mal de Doxa)
soit sur que si un jour Helson paye de la pub la bas le post "disparaitra"
le créateur du WUS est un mec qui fait du business .... pubs, bandeaux, sponsors idem pour les Timezone et consorts tant que tu ne fais pas de vague sur le business tout est bon a dire, quand tu touches a la pompe a fric la tu comprends
il n'y aura jamais de pub sur MDP en grosse partie pour cette raison, j'ai assez vu le coté pervers de la chose quand j'étais modo chez WUS
Ce qu'il va être intéressant de savoir c'est quelle sera la réaction de Peter Helson, et quand elle aura lieu.
» L'équipe Cousteau et ses montres : suite de la suite du feuilleton
» HELSON ??
» Helson : les news
» Une bordée d'Helson
» Helson SHARKDIVER
» HELSON ??
» Helson : les news
» Helson SHARKDIVER
Page 1 sur 6
