Zeno Army retro diver orange vs Doxa sub 750T prof.
La Zeno:
Case
diameter 40mm - thickness 17mm - 316L stainless steel, polished, engraved solid stainless steel unidirectional rotating no-decompression dive bezel with ratchet, double protected diving crown and solid screw-on back
water resistant to 30 ATM (1000feet), shock resistant, antimagnetic (tested for DIN 8308, DIN 8310, DIN 8309) - duoblock construction
The unidirectional turning bezel has two marks at 1200
Glass: vintage look domed acrylic crystal (extra thick)
Dial:orange with big luminous markers, Superluminova advanced lllumination hands and numbers, tested for DIN 8306
Band:48M3I integrated stainless-steel (polished) bracelet with progressive width and strong deployment flip-lock buckle, double lock security clasp, massive links and solid attachments (available in satin finish)
Movement
High quality Swiss Made mechanical/automatic winding with quick-set date. ETA 2836 - 25 jewels, Swiss lever escapement, Incabloc shock absorber, Glucydur balance, Nivarox 1 flat spiral, Antimagnetic, 28´800 vibrations per hour, Nivaflex spring, ball bearing central rotor with heavy metal weight, power reserve to -47h, Etachron fine adjustment, tight tolerance of adjustment
(variations with Cal. 2836, 2846, 2452)
La Doxa:
Colour vibrant Orange
Limited Edition
5000 pieces only
Case
Satin brushed solid stainless steel (316L). 44.70 mm in diameter (excluding crown). 14.00 mm in height. Stainless steel screw-down crown at 3 o'clock. The 750T Professional is water resistant to a depth of 750 meters (2460 feet), and is hand assembled in Switzerland.
Crystal
Anti-reflective, scratch resistant sapphire crystal (3mm)
Case back
Stainless steel screw-back case back engraved with limited edition number xxxx/5000
Bezel Solid stainless steel unidirectional bezel. Engraved with the US Navy maximum no decompression limit times in feet (NOT METRIC). [bezel operating instructions]
Movement
High grade 25 jewel self-winding Swiss made movement with hacking seconds. 28,800 beats per hour, 42 hours of power reserve. Based on the ETA 2824, modified and decorated by DOXA.
Anti-Shock
Incabloc shock protection
Functions
Hours, minutes, seconds, quick set date at 3 o'clock
Hands
Replica of the 1969 hands featuring updated superluminova to ensure luminosity, and DOXA's famous "dwarf" hour hand.
Bracelet
Solid stainless steel. Faithful replica of the original DOXA SUB, updated with wetsuit extension and an ADDITIONAL high quality signed rubber strap link, and 21 mm end pieces.
Presentation
DOXA's world-famous "scuba bottle" presentation case made of heavy anodized aluminum
Additional
High quality Bergeon® screwdriver and additional original DOXA SUB signed rubber strap, see details here: www.doxawatches.com/rubber_strap_sub750.html
Warranty
DOXA's 2 year limited warranty
Operating Manual
included
Prix: Doxa: 1969 $
Zeno: 369€
Messieurs (et Mesdames) vos avis!
Case
Movement
La Doxa:
Limited Edition
5000 pieces only
Case
Crystal
Case back
Movement
Anti-Shock
Functions
Hands
Bracelet
Presentation
Additional
Warranty
Operating Manual
included
Prix: Doxa: 1969 $
Zeno: 369€
Re: Zeno Army retro diver orange vs Doxa sub 750T prof.
Attention, cette version de Zeno n'a pas de couronne vissée !!
for me: look super de la doxa. Rapport qualité / prix: les deux sont assez proches niveaux specs (abstraction du saphir, mais le plexi de la zéno, j'adore!) mais niveau prix la Doxa ...cartonne!
Avantage Zeno pour moi.
ah pas de couronne vissée!! Est-ce rédhibitoire? Oui..?
c'est quoi ce "double protected"?
Il vaut mieux comparer la Zeno avec la Doxa Sub 250
(source http://www.thewatchforum.co.uk/index.php?showtopic=13093 )
Dynamo
Dynamo
ok dyn mais elle est encore au catalogue à ce prix?
non c'est une série limité comme Doxa adore, mais je suppose que le veritable fabricant été Zeno
Dynamo
Dynamo
salut alemar
dis moi si je me trompe mais ne serais tu pas en train de loucher sur les zenos ????
en tout cas c est vrai qu elles ne laissent pas indifferent et a des prix tres cool ...
j en suis la preuve, moi j aime assez leur coté 70.80' un peu decalé
quoiqu on en dise elle suffise a tous plongeurs loisir, c est pour moi une evidence !
et le mouvement eta ca change des 7s26 de seiko on gagne enormement de precision , la trotteuse est plus fluide
pas de couronne vissée ! c est pas pour moi un obstacle j ai une quartz depuis plus de 10 ans avec une couronne poussée et pas de soucis , donc...
de plus timefactor est un bon dealer commendé le dimanche, arrivée le mardi matin suivant !!!
bon choix a toi si tu en est la mais en tout cas pour moi c est ok
bonnes bulles
bonnes bulles
- Nombre de messages : 2962
alemmar a écrit:for me: look super de la doxa. Rapport qualité / prix: les deux sont assez proches niveaux specs (abstraction du saphir, mais le plexi de la zéno, j'adore!) mais niveau prix la Doxa ...cartonne!
Non, si tu l'utilises en terrestre, par contre plonger avec, ça craint si la couronne se tire...
Allez, je me lance Alemmar. C'est clair qu'en matière de montre, le
tarif n'est pas un critère de choix raisonné et objectif pour certains
clients. Doxa à une histoire, Zeno moins ou pas. C'est pas dans les
caractéristiques, ni dans le portefeuille qu'il faut chercher, c'est
dans le coeur des gens. Les américains (principaux clients de Doxa) ont
les aventures du héro fictif de Clive Custler en tête, nous on a
l'équipe Cousteau où elle est apparue avec d'autres. Une époque précise
qui va avec la "Doxa Sub" 1968-1969 exactement...Cette drolerie
qu'on buvait dans une p'tit taule près de Bien Hoa, les volets rouges,
la taulière, une blonde comak, comment qu'elle s'appelait nom de d...?
Me suis-je posé seulement la question lorsque j'ai achété la mienne? 3
Zenoau lieu d'une Doxa? Vaut-il mieux 3 machin-chouette plutot qu'une
Speedmaster Pro...Neil Amstrong, un petit pas pour l'homme, un pas de géant pour l'humanité. Nous sommes venus ici en paix au nom de toute l'humanité, etc.. etc.. Quel prix cela a t il?...
Marc
Marc
deux montres difficilement comparables : pour avoir eu les deux en main ... il n'y a pas photo , le niveau de finition de la Doxa est TRES clairement au dessus , les "specs" ne veulent rien dire "brut de fondrie" ...
bien sur le "même mouvement" mais ... c'est faux ! le 2824 de la Doxa est un "elaboré" celui de la Zeno un basique : tout est différent dans le mouvement jusqu'au materiau des rubis (polycristallin sur le basique , monocristallin sur l'elaboré), le spiral est différent, les usinages sont différents
la qualité du boitier : prend les deux en main ... incomparable
le bracelet : no comment
Bref chacune dans sa "niche de marché" et pas comparable
Rappel : la Zeno utilise une autorisation de doxa pour la produire (brevet sur la table de déco) preuve qu'ils ne concidèrent pas Zeno comme concurent
ma conclusion : pour 300 euros j'achete ... une Seiko
et la doxa ... j'en ai 2
marc_wl a écrit:Allez, je me lance Alemmar. C'est clair qu'en matière de montre, le
Marc
Egalement entierement d'ac Marc .... MAIS dans le cas précis aussi TOTALEMENT incomparable en qualité !
une Zenau ... non merci je prefère 100 fois une Seiko pour le prix , la Zenau aura toujours un parfum de "copie" meme si cette copie est authorisée par l'original
Zeno ou Doxa ?
Albert Falco
JY Cousteau
Jean-Michel Cousteau
Philippe Cousteau
Albert Falco encore
Albert Falco
JY Cousteau
Philippe Cousteau
Albert Falco encore
Speedmaster Pro...
un argument qui fait mouche! En plus de l'argumentaire technique de JM (quoique moi le mono ou polycristallin pour les rubis je demande des détails!)...
Quoiqu'il en soit il faudrait effectivement pouvoit les comparer de visu, comme d'hab!
Et pour finir ...mon point de vue: je trouve cette zeno sympa et bien placée niveaux prix, si on n'a pas 2000€ pour la doxa, ça console (un peu)
Je suis d'accord avec toi Alemmar. L'augmentation des tarifs Doxa de
Juillet a été le "coup de fusil" brutal (auquel j'ai coupé le dernier
jour de lapromo et en plus JM m'avait refilé sa réduc client
supplémentaire!!).
Je crois que Doxa a anticipé sur la dose affective des clients
potentiels qui ont des motivations spéciales vis-à-vis de la marque.
Sans ces motivation je comprend qu'on zeute la jolie Zeno même dans un
grade technique inférieure en calibre horloger.
supplémentaire!!).
Jean-Michel a écrit:Zeno ou Doxa ?
A ton avis JM ?
Allez... une ptite image pour l'aider à choisir.
Et j'suis bien placé pour voir la différence, j'ai aussi une Zeno, la Diver 300.
C'est sympa certes, mais bon quand t'as la Dox entre les pattes...
- Nombre de messages : 8534
alemmar a écrit:(quoique moi le mono ou polycristallin pour les rubis je demande des détails!)...
ho P... un qui me fait bosser !!! le saphir c'est aussi un peu mon boulot j'en usine toute la journée !!!
bon rapidement :
le monocristallin : fait a partir de rubis synthétique poussé par procédé Verneuil (cherche sur le web cela doit etre expliqué) , puis coupé en petits carreaux, usiné, poli ...
polycristallin : poussière de saphir compactée et moulée a haute température : beaucoup moins cher, beaucoup moins beau (laiteux) nettement moins solide, structure moins cohérente et moins glissante (microfissures)
Bref deux materiaux différents même si tous les deux du rubis .... en dehors de l'esthétique les rubis monocristallins sont supérieurs techniquement pour leur etat de surface et leur solidité
pas besoin de chercher, j'ai compris: d'un côté un vrai cristal, de l'autre un agglomérat.
ok!
ok!
Oui et non
une ZENO Army = Reedition Doxa Sub 250 (pour celle de la même période sont parfaitement identique sauf le cadrant)
Dynamo
Dynamo
Etant possesseur de la Doxa, vous allez dire que voilà un avis bien loin d'être objectif, mais quand je vois la belle à mon poignet, et que je regarde la photo de la zéno, je me dit qu'il n'y a pas photo entre ces deux montres. Mon coeur ne balance pas une seconde (il n'y a que mon bras qui balance, sous le poids de la bête)
Thomas
Thomas
Comme l'a dit Dynamo, il faut comparer ce qui est comparable et surtout à boîtier identique ! Je ne vois pas l'intérêt autrement. Donc la Zeno en photo avec la Doxa 250T et aucune autre... le boîtier typé 70 n'ayant strictement rien à voir.
Pour ce qui est de la finition, je ne connais pas le niveau de finition de l'époque d'une Doxa 250T, et pas une autre...
le niveau de finition de la 250T etait similaire a la Zeno c'etait un modèle d'"entrée de gamme" doxa ... la marque cherchant a monter en gamme je ne pense pas qu'on revera un modèle identique
ohedubateau a écrit:Etant possesseur de la Doxa, vous allez dire que
Thomas
Et pas n'importe laquelle dubateau!!! :
Ta montre quotidienne?
Elle est effectivement devenue ma montre quotidienne. On ne sait jamais, si par inadvertance par temps de pluie je tombe dans une flaque d'eau de plus de 700 m de profondeur, je suis prêt et équipé pour.
Petite question aux possesseurs de cette DOXA : je note une dérive d'environ 7 secondes /jour sur une semaine; pensez vous qu'un réglage plus fin du moteur de cette montre est possible ?
un ETA 2824 de ce grade peut être en effet réglé "au petits ognions" par un régleur compétent : maintenant est ce que cela vaut le coup ? a toi de voir, franchement je ne me focaliserai pas trop la dessus vu que tu n'es quand même pas loin de la spé COSC et je laisserai un peu de temps afin de voir d'éventuelles dérives
mais il est certain que l'ETA 2824 dans ces grades haute qualité utilisé par doxa peut être un garde temps TRES précis
de mon coté je me suis permi une petite régulation du mien (j'ai un chronocomparateur a la maison + l'outillage d'ouverture/fermeture) et le résultat est dans le seconde par jour ! pas mal pour un mouvement dis "économique"
Merci Jean Michel pour ces infos.
Maintenant je sais que si un jour je me lève avec une envie irrepressible de fleurter avec la seconde de dérive par jour, comme à la scnf (ou à la Matmut selon la pub), c'est possible.
Thomas
Thomas
» Zeno Army 300 sur coutchouc
» Zeno Army 300 sur cuir noir troué
» (revue) Doxa 750T Carribean
» Besoin d'aide pour port Zeno Army 300 habillée ;-)
» DOXA SUB 750T vs SUB 1000T
