meme a St trop. ils peuvent rire ( breguet inside)
si vous ne deja en voyant la photo, alors lisez ci-dessous et je pense que ca peut venir ...
this year brings a groundbreaking new design: the Marine Royale alarm watch, water-resistant to 300 m.
Breguet's Marine Royale 5847 comes with an alarm device that can only delight both amateur divers and aficionados of exceptional complications. Underwater tests confirm that sound travels better through water than through air. Sound waves require material support and their speed increases with the density of the environment. Sound travels about four times faster under than above water. Furthermore, as the underwater milieu is generally far less noisy than the aerial one, the alarm's sound is perceived with greater clarity underwater.
The alarm setting crown and on-off pushpiece, in gold, are sheathed in rubber for easier handling, adding a further touch of sporty elegance. The watch naturally possesses the usual diver's-watch features, not least a one-way rotating bezel inscribed with a graduated 20-minute sector. The bezel's unidirectional rotation is secured by a blocking pawl, visible and located between the two winding crowns on the case flank. Shaped like a wave, it recalls the watch's essential functions. To improve its legibility even in the murkiest waters, its minute markers and hand along with the hour hand are coated with white luminous superluminova while the hour and alarm markers glow blue. Represented by a blue triangular pointer at 10 o'clock, the power-reserve indicator is also luminous.
Rounding out its attributes, the Marine Royale 5847 possesses a date indicator and a self-winding mechanism. The white gold version comes with an 18 kt dial with black rhodium finish while the pink gold version features an 18 kt pink gold dial. Both are manually engine-turned with the collection's dedicated wave pattern.
Re: meme a St trop. ils peuvent rire ( breguet inside)
euh, comment dire... l'alarme c'est pour prévenir les poissons qu'on arrive et qu'ils aient le temps de déguerpir
Oh mon dieu...
J'ai mal à Bréguet...
et voila un nouvel objet qui ne sert que l'ego de celui que le porte...
tres curieux de voir une competition sur une complication aussi improbable que la plongeuse alarme de grand luxe. JLC en a soti ( ou ressorti).
la description des soit-disant recherches pour montrer que le son se propage plus vite ds l'air que ds l'eau est un morceau de bravoure de marketeux. Va bientot falloir qu'on invente un autre trophee pour honorer le plus beau verbiage...
ce n'est pas le mariage de la plongeuse et de la complication alarme qui me gène... je la trouve d'ailleurs plutôt sympa cette complication pour se lever le matin... et il y a un océan je trouve entre la réédition Polaris et ça...
Ohhhhhh, mais c'est la montre du capitaine Némo !!!
ou peut-etre la montre du poisson nemo du film d'animation
"Underwater tests confirm that sound travels better through water than through air"
c'est bon , après ça je ne lis plus!!! Niveau Collège 5e.
alemmar a écrit:"Underwater tests confirm that sound travels better through water than through air"
preuve que les marketeux sont des nuls ! merci Mr Breguet de nous confirmer que vos crétins communicants ont eu besoin de mettre la tête sous l'eau pour constater que les sons se transmettent parfaitement dans l'eau
l'avantage , c'est que sous l'eau on entend peut être les alarmes Breguet mais pas la connerie des reponsables de promo
Lionel tu aurais eu une bien meilleure idée marketing pour cette montre en communiquant en clin d'oeil sur "la montre du Capitaine Nemo" sur fond d'illustration d'époque de Jules Verne. Ceci aurait été 1000 lieues sous les mers plus sympa que ce discours de c... sur la physique niveau 5ème demontrant la nullité intellectuelle des responsables marketing.
Je pense que cette montre peut avoir en effet ses adeptes, elle peut faire voyager l'esprit...
micromeca a écrit:Je pense que cette montre peut avoir en effet ses adeptes, elle peut faire voyager l'esprit...
Fallait juste demander à
Hé? Ca aurait eu une sacrée gueule ...
Il faut vendre du rêve, le rêve n'a pas de prix...
micromeca a écrit:Il faut vendre du rêve, le rêve n'a pas de prix...
Le rêve n'a peut être pas de prix, mais il a un coût, quand il s'appelle BREGUET...
Cette montre me fait mal aux yeux,je passe vite à d'autres choses avant de faire un cauchemar!
» Votre montre du jour
» Ma crise était trop grande, j'ai craqué... Sinn (bientôt) inside
» Un premier wristshot (même un deuxieme). Jlc inside
» une vraie St trop (Ulysse Nardin inside)
» Comme quoi les goûts peuvent évoluer...
