angular momentum veut aussi la coulee du grand bronze
une tite news passee inapercue.
cette fois ils justifient le choix technique du bronze.
BRONZE „aer aeris“ - an extraordinary material
June 1st 2010, Angular Momentum has introduced its first BRONZE timepiece the Freehand Beryllium Diver Magnus, which has been published in magazines, blogs and forums around the world.
After many tests and investigations Angular Momentum has decided to integrate the material bronze in its collection and to develop a specific Bronze Collection. Respectively to offer all timepieces not only in all golds, Platinum or 1.4435Cnu steel but also in Silicon Bronce, the most suitable and hardest among the Copper alloys.
Why Bronze:
Silicon Bronze is a high-strength, highly corrosion resistant material with nonmagnetic properties. It is generally as strong as steel. The cost of copper-base alloys is generally higher than that of steels
Reason No.1 Corrosion
Bronze resists corrosion (especially seawater corrosion) and metal fatigue more than steel and is also a better conductor of heat and electricity than most steels.
Reason No.2 Surface quality
There are various polishes used to clean bronze. The bet are those, developed for Instruments such as Saxophones often made of Bronze. The application of such polishes will preserve the luster and shine of the surfaces for decades. There are also people who love the "Antique" touch of not treated bronze. Bronze does not scratch lighter than steel or gold
Reason No.3 Hardness
Its excellent hardness (even harder than 316L stainless steel) compared to other metals used in watch industry
Silicon Bronze 200-230 HV (Vickers)
316L Stainless steel 190-210 HV (Vickers)
Titanium grade 5 150-190 VH (Vickers)
Titanium Grade 5 cold formed 250-300 HV (Vickers)
White gold 150 - 180 HV (Vickers)
Diamond 10'060 HV (Vickers)
Reason No.4 Color
The Silicon Bronce has a beautiful warm color, close to red gold
pas de photos.
faites un tour sur leur site:il y a une image en page d'acceuil.
http://www.angularmomentum.com
Why Bronze:
Reason No.4 Color
pas de photos.
Re: angular momentum veut aussi la coulee du grand bronze
mouais... ben je me relèverais pas la nuit pour un bronze...
va y avoir une épidémie de poignet noircits....
- Nombre de messages : 1070
Fabrice a écrit:mouais... ben je me relèverais pas la nuit pour un bronze...
+1
Les fabricant de cloche font du recyclage ?Ah les modes!!!!pas booooo!!!!,mais moins pire que les deux autres présentées!
- Nombre de messages : 4981
Tout dépend de ce que tu as mangé la veille...
mes réponses entre les lignes
Why Bronze:
non moins solide que la plupart des aciers inox, en particulier que le 316L : amagnétique oui je le concède mais le 316L est aussi faiblement magnétique
la encore une "généralité" certains bronzes sont moins chers que des aciers techniques ...
oui le bronze résiste a la corrosion ... en s'oxydant en surface et se couvrant de vert ... c'est moche ! quand au 904L il est lui totalement insensible a l'eau de mer et au moins ne vire pas en couleur ... conducteur de chaleur oui c'est vrai mais je ne savais pas que l'on faisais des radiateurs ... je croyais qu'on parlais de montres
ce n'est pas pour rien que l'on recouvre le laiton des robinets de plongée d'une couche de nickel , car si le laiton comme le bronze est tres résistant a la corrosion en profondeur, il se couvre d'une couche d'oxyde vraiment moche si on ne la protège pas
alors la je rigole l'état de surface du bronze après une simple oxydation a l'oxygnèe de l'air c'est ... moche ! ça prend une teinte noire dégeulasse j'en chie assez professionnellement avec ce probleme pour être complètement contre cet argument ... on veut nous faire passer du degeu pour de la patine !
la solution serai d'y appliquer une vraie patine de sculpture, mais ce n'est pas le cas (les patines de sculpture sont réalisées a partir de mélange d'acide on peut obtenir des teintes du vert au brun en passant par le noit
la c'est du n'importe quoi cela dépend de l'alliage mais surtout de l'état (écroui ou non) les aciers inox sont en général beaucoup plus dur que les bronzes ! d'ailleurs la supériorité historique des armes en fer contre les armes en bronze n'est plus a démontrer ! seul le bronze bérylium a une dureté approchante de l'acier inox mais cela m'étonnerai que les fabricants de montres s'amusent a l'utiliser au vu du prix au kilo !
Reason No.4 Color
oui attendez de voir dans 6 mois quand elles seront bien noires et dégeu avec les proprios se passant des trucs et astuces pour les passer au Mirror
Why Bronze:
Reason No.4 Color
Jean-Michel a écrit:mes réponses entre les lignes
Why Bronze:
Reason No.4 Color
Vinaigre blanc et gros sel. Recette de ma mamie.
Jean-Mi les a rhabillé pour l'hiver (c'est pas mal pour une tocante )
Il y eut l'âge de bronze, puis l'âge de fer et maintenant... on y retourne et on en coule un.
» [nouveauté] Angular momentum Berylium diver
» lum tec coule un bronze ...
» rolex qui qu'en veut? daytona? y en a aussi...
» La plongée où on veut et quand on veut !
» Montres en bronze... Ah ah ah...
